Fixing Raisers Edge Constituent
I was wondering whether anyone could help me.  We have about 700+ constituents with the wrong constituency codes.  I have an excel spreadsheet with what the constituency codes should be.  How do I fix this?  Any help would be appreciated.
Thank you
  • Hopefully that spreadsheet contains Import IDs or Constituent IDs.  If so, it's easy enough to add Constituent Codes through an import file. Here is the Knowledgebase article that will help.
    Global Add is another option, if the names on that spreadsheet were pulled from a query.  You can use that query to add the constituent code to all of those records (this is the easier way, in my opinion!).
    Good luck!
    Katherine
    WIST Data Solutions
  • Thank you Katherine Mannion.
    Do you know whether it will update the Constituent codes or do I have to go in and delete the old ones?
    Susan
  • You'll have to delete the old ones.  If you do the change with an import file, you will be able to create an output query of updated records that you can use to delete the old codes.
  • Thank you Katherine.
    Susan M.
    Stanislas
    Advancement Database
    Manager
    Notre Dame High
    School
    13645 Riverside
    Drive
    Sherman Oaks, California
    91301
    818-933-3692
