Assigned Appeals
Is it possible to globally delete an assigned appeal from a query of records?
  • Austen Brown
    Ninth Anniversary 2,500 Likes 1000 Comments Photogenic
    Hi Cathy Hall‍ - Yes, it is possible.  Check out KB Articles #52838 and #41140 for instructions on how to accomplish this.  A few pieces of advice, make sure you run a "Pre-delete Report" prior to deleting the records, this will help ensure that the "Global Delete" window is filled out correctly and help you will be successful in deleting the information you want to remove from records.  Additionally, it would probably be a good idea to make sure you have a current back-up of your system prior to starting (if you are hosted, note the time before you begin so that if you need to contact Blackbaud to restore your system they can return it to where it was before you ran the global delete).  Let me know if you have any questions. Good luck.
