NXT Database
Hi,
We've just started using RE and I am creating a schema to help my colleagues understand the database better.
I'm trying to find out what database NXT uses.
Does anybody have the following information about the Tables and Columns in the database:
TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
ORDINAL_POSITION
COLUMN_DEFAULT
IS_NULLABLE
DATA_TYPE
CHARACTER_MAXIMUM_LENGTH
CHARACTER_OCTET_LENGTH
NUMERIC_PRECISION
NUMERIC_PRECISION_RADIX
NUMERIC_SCALE
DATETIME_PRECISION
I look forward to hearing from you.
Chris
TABLE_CATALOG
TABLE_SCHEMA
TABLE_NAME
COLUMN_NAME
ORDINAL_POSITION
COLUMN_DEFAULT
IS_NULLABLE
DATA_TYPE
NUMERIC_PRECISION
NUMERIC_SCALE
DATETIME_PRECISION
Chris
With NXT you can't access the database directly, so unless your colleagues work for Blackbaud none of those would be of any use.
That said, on a locally installed copy of RE the data dictionary can be found at C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Help\\RE7Schema.chm
Hi John,
Thank you for your response. We are hosted in Blackbaud SKY, do you know how we could access this using the SKY API?0 -
SKY API doesn't access tables directly. All of the fields you list have more to do with the database structure than the actual data and are irrelevant to SKY which will automatically handle any function provided by those fields. Check out this forum for more information on using SKY: https://community.blackbaud.com/forums/viewcategory/4231
Further to John Heizer's and Mergen Peries's answers, there are Endpoint Schemas - for example, https://developer.sky.blackbaud.com/docs/services/56b76470069a0509c8f1c5b3/operations/GetConstituent (then click Schema) - as well as Entity Descriptions, for example https://developer.blackbaud.com/skyapi/apis/constituent/entities#Constituent.
Each has its uses.
Cheers,
