Address Finder - use of 'attn, care of'
I am about to run address finder. I am a bit confused about how to manage "Attn" and "Care of." We have that in line 1of our addresses but NCOA puts it at the end of the address. How do you cope with that so when you print a label the label will show correctly.
Terry
  • Interested to see if you ever found a work around for this? I don't believe there is a way to do it with Address Finder, unless you, exported all of the addresses that have a care of line, with the address import ID, run address finder and then re import the addresses in with the format you prefer...
  • Thanks Claudia,
    That will work for the small number of cases we have.
    Terry
  • I am a little late to the party on this question...did you find a work around or a solution?
