Like vs Contains
Chher
I would use Like instead of Contains if I was looking for something that I know must begin with a series of characters, not merely contain it. The query "Name like Alan%" is going to run much more quickly than "Name contains Alan" since RE can immediately disregard any value that doesn't begin with the word Alan.1
Alan French:
I would use Like instead of Contains if I was looking for something that I know must begin with a series of characters, not merely contain it. The query "Name like Alan%" is going to run much more quickly than "Name contains Alan" since RE can immediately disregard any value that doesn't begin with the word Alan.Cheers Alan, would you not use the Begins With operator in that example though?
Yes, good point and bad example!1
Contains is usually used to compare one item, for example: "Smith" with a list of items: "Smith, Lane, Johnson, Carter"
Like is used to compare one item "Smith" with "Smi%". This will return not only Smith, but Smitty, Smithy, etc.
Does that help?
Thanks!1 -
Tim Stahl:
Does that help?
Thanks!Cheers Tim. To get the same result as the Like example above, I could just use Begins With "Smi" though right?
Yes! Absolutely. Like can also be used to find things in the middle of a word, for example: "%are%" could match to Care, or area.1
That's what Contains does!1
Perhaps Contains was added more recently to remove the need to use wildcards? I guess not everyone is familiar with how to use them.
Does anyone have the RODBA module and can test whether the query generates the same SQL code for both "contains Smith" and "like %Smith%"? I'm intrigued...1 -
Alan French:
Does anyone have the RODBA module and can test whether the query generates the same SQL code for both "contains Smith" and "like %Smith%"? I'm intrigued...That's what I was thinking. It would appear that Like and Not Like can replicate all the functionality of at least Begins With, Does Not Begin With, Contains and Does Not Contain, assuming appropriate use of wildcards. I just want to make sure I'm not missing something!
Yeah I have RODBA and took a look. If you say first name contains Jam, the SQL it generates is:
WHERE [first_name] LIKE '%Jam%'
Like just translates whatever you put in there to SQL. So if you say first name like Jam*, the SQL it generates is
WHERE [first_name] LIKE 'Jam%'
So yes, it'll probably be quicker if you use like and specify your wildcards, but only if you have the wildcard at the end of the string rather than the beginning, because if you say first name like *Jam*, it'll return the same SQL as if you say first name contains Jam.3 -
You're good to go, that's correct! Like and Contains are really SQL database terms. When dealing with database folks like myself, those just make sense to me :-)1
Perfect, cheers James. Reckon I'll just use Like as I would in SQL just to avoid any ambiguity!1
Tim Stahl:
You're good to go, that's correct! Like and Contains are really SQL database terms. When dealing with database folks like myself, those just make sense to me :-)From the RODBA extract it doesn't look like the the Contains operator is equivalent to the CONTAINS predicate in SQL though. It's just mapping it to LIKE with bounding wildcards. So it appears there's no functional difference between the two RE operators besides the requirement to include at least one wildcard when adding a Like, i.e. there's no functional or performance advantage to using Contains "badger" over Like "%badger%".
3 -
Grant Quick:
From the RODBA extract it doesn't look like the the Contains operator is equivalent to the CONTAINS predicate in SQL though. It's just mapping it to LIKE with bounding wildcards. So it appears there's no functional difference between the two RE operators besides the requirement to include at least one wildcard when adding a Like.Yeah exactly. Contains just cuts out a couple keystrokes for the user, is all.
2
