Issue with page in Mobile version
Hello All,
I have basic to intermediate knowledge in CSS, and I have a page that does not render correctly when using mobile.  Everything else looks renders correctly in mobile except menu does not show when you click on the 4-5 horizontal line  to see Main Menu.
https://secure3.convio.net/pnfou/site/Donation2;jsessionid=00000000.app30125b?idb=1938585028&df_id=2140&mfc_pref=T&2140.donation=form1&NONCE_TOKEN=1E6DE6EFCD9331AD80B29757C9BA5F83&idb=0
Abdi
  • Hey Abdi,
    I think this might be an issue with your modernizr.js file. The reference points to https, but it cant load it over https for some reason. I can load it on http:
    https://foundation.parknicollet.com/teamraiser-themes/theme1/js/modernizr.js Firefox throws an error message and I see it in the console when inspecting your code
    http://foundation.parknicollet.com/teamraiser-themes/theme1/js/modernizr.jsThis does load. Check it out in your code.
    It is referenced as this:
    <script src="//foundation.parknicollet.com/teamraiser-themes/theme1/js/modernizr.js"></script>
    I noticed your credit card images were stacking as well. You need to do some CSS changes, but I don't know how else they will affect your site.
    inline.css
    #content img
    display: inline;
    bootstrap.min.css
    vertical-align: top;
    CustomStyle.css (this you might have to overwrite due to this being your LO stylesheet)
    ul,li
    text-indent: o;
    Let us know how it goes,
    Phil
  • Hi Addi,
    I recognize the wrapper template you are using, and I have dealt with similar issue before. You are missing some Bootstrap parameters in your <button> tag - it's either in a the wrapper HTML or a reusable. Try update the Button code to this, and it should work:
    <button class="navbar-toggle" data-toggle="collapse" data-target="#header-nav">
    Good luck.
    -Francis
  • Philip Nawrocki:
    Hey Abdi,
    inline.css
    #content img
    display: inline;
    bootstrap.min.css
    ul,li
    text-indent: o;
    Phil
    Thanks, Phil.
    Where would this file be in LO: http://foundation.parknicollet.com/teamraiser-themes/theme1/js/modernizr.js? I cannot seem to find it anywhere.  I'm also having hard time finding these files CSS files you noted:  (inline.css, bootstrap.min.css).  I can only see CustomStyle.css and able to fix that css code.
  • Francis Lim:
    Hi Addi,
    Good luck.
    -Francis
    Thanks, Francis.
    Will take a look at that.
