Participant Options Not Formatting Correctly - TeamRaiser
For one of our TeamRaiser events, when a user gets to the registration form where they are to choose a Participant Option, the options are appearing in an inconsistent/confusing way (see attached screenshot).  Where do I find the code to fix this? Do you have any recommended solutions for a change in code?
I would like to add that we have another TeamRaiser event that is live and the Participant Options are formatted correctly and consistently.
  • Hi Austen,
    I would guess this is due to some type of errant code in the wrapper.  Do both events share the same one?
    Feel free to connect with me directly at mark@cathexispartners.com
  • Austen Brown
    Ninth Anniversary 2,500 Likes 1000 Comments Photogenic
    Mark Becker‍ - Thanks for the reply! The two events have their individual page wrappers. Is there a way to easily compare the page wrappers to see what is different in each?
  • Hi Austen and happy Friday!
    This would most likely need to be fixed through CSS.... so we'd need access to their instance to see how that wrapper was built and which style is causing the mis-alignment.
    Are you going to be at BBCon?  If so, stop by our booth and we can have a look see.
  • Austen Brown
    Mark Becker‍ - Yes I will be a BBCon.  Thanks for your offer to help with this.
  • Great!  I am sure we can figure it out in no time if you can wait until then.
    We are booth #403 in the Expo hall.
  • Not trying to step on Mark Becker‍ toes for BBCon, but Austen Brown‍ If you posted a link to the TR in question right now, the community could probably help you solve this.
    Just trying to help you not wait 2 weeks.
    Phhil
  • Austen Brown
    Philip Nawrocki‍ links to the each event's registration page are below.  Thank you for your offer to help.
    Event with Formatting Issue
    Event with Correct Formatting
  • Hey Austen,
    If you want a quick fix. Try making the descriptions for Recreation and Advanced participation types shorter.
    In the event that works they are super short, so the issue isn't appearing, but if you made the descriptions longer, they would.
    You could take this copy off right away from all three options:
    Available to all players.
    Will see what else I can come up with code-wise.
    Phil
  • Following CSS will do the trick
    div.part-type-container{
    border: 2px solid transparent;
    margin: 5px 0;
    div.part-type-container input{
    float: left;
    div.part-type-container .part-type-decoration-messages{
    display: block;
    margin-left: 35px;
  • Austen Brown
    Romany Nassief‍ Thank you so much! It's fixed!
