Pictures are pixilated when creating new email
I've uploaded an image to my email campaign I'm designing and it shows up super blurry. The file I'm using is much larger than what is required so it should not be pixilated. Is this how the picture will show up when it's sent out? Are there specific picture files that work best in Online Express?
  • I am having the same issue or photos/logos are coming up massive. I have tried re-sizing outside of OLX but can't seem to be able to make it work and I can't find where to adjust inside the program. When you do the test email to yourself you can see how it will show up and it looks bad.
  • Brandon Lebrock‍, I've had this pop up in letters before - it had to do with the difference between copying & pasting the image vs. using the insert feature of Word.  So, test this out and see if it helps.  If you copied and pasted, try inserting instead, or vice versa if applicable.  That's the only idea I have, so I hope it works!  (Fingers crossed!)
