Is there a file size limit for the Document Library?
The Document Library has a limitation of approx. 10MB per file. If you need to upload a larger file, you will need to use FTP and this requires that you have some type of FTP software available on your computer to do the upload. Additionally, you will have to call Convio Support to get the username/password and host information needed to set up the connection in your FTP software.
The total limit for the entire library depends on your contract, which specifies the maximum number of files that you can have active at any time in your Library.
Document versions do NOT count toward the limit - Convio "counts" only live versions.
I have tested this with some rather large files of my own and it does infact apply to document and image library.
-Sarah Boger
Support Analyst
