Export of consecutive Donors
I need to pull an export of consecutive donors  (5 years) whose total gifts each year are greater than or equal to $1000.
  • Donna Marino:
    Hi Donna!
    That answer is in Knowledgebase - Article Number: 38482.
    Good luck!
  • Donna Marino:
    There is a canned report that does that.  Under Analytical Reports.  And if that does not have the info you want on the output of the report, you can always have the report output a query you can export with the fields you require
