Addresses doubling up in Raiser's Edge.
Has anyone had the problem of addresses appearing twice on reports? They even appear doubled on the address tab of the constituent record. I have check knowledgebase and the only viable answer I could find was to delete the address and re-enter. That didn't work!! Does anyone have a solution? Thank you!
    Have had the issue before of double on records. Don't recall the solution if there was one. Support told me the duplication was caused by copy 1 of address on constituent record and copy 2 pulling from a relationship. This was when running 7.93 - I haven't looked for since update to 7.96.  Solution may have been to use address share on the relationship address but I don't recall for certain.
  • JoAnn, thank you for your response. I actually had to go into Config, International and open the record for US- it was duplicated in the address block area.
    I love your profile picture, are you from South Dakota?
