Does anyone know anything about using SWFOBJECT with Flash files in Pagebuilder
I have a SWF file that for the sake of variable changes I need to use the SWFOJECT file. Has anyone had any luck using this method of Flash implementation in Pagebuilder? The file is a small flash video player with text playlist beneath it. Any suggestions?
Just to be certain, I presume you mean this:
http://blog.deconcept.com/swfobject/
I just tried a test and it seems to work ok:
http://action.sierraclub.org/site/PageNavigator/adriantest_delete
You may however, want to put the SCRIPT call in the pagewrapper. And put
swfobject.registerObject("myId", "9.0.0", "expressInstall.swf"); in window.onload, or body onload call
otherwise, there is the potential that swfobject could get called before the javascript object exists on the page.
Some things that might cause it not to work:
js file not being loaded (wrong URL or something)
path to swf files incorrect.
Firefox+the Firebug plugin is a good way to troubleshoot Javascript issues.
Adrian Cotter:
Adrian, I don 't see any flash on your test. Just your page wrapper and "asd asd".
