Donor error message-how to alter
How can you change the error message received when required fields ar not filled in.  Below is a screen shot of the Fine tuning tab where this field appears. - Any suggestions?
If registrants submit forms with errors such as missing data, then error messages appear here
  • Bonnie Chamberlin:
    How can you change the error message received when required fields ar not filled in.  Below is a screen shot of the Fine tuning tab where this field appears. - Any suggestions? If registrants submit forms with errors such as missing data, then error messages appear here
    It's under 4. Fine Tuning select Messages and you can edit the wording, change the color, etc...
  • I can change the color of the background, the text and the boarder color and kind, but it will not let me change the words. I tried highlighting, deleting backspacing it remains.
    If donors submit forms with errors such as missing data, then error messages appear here.
    I can change the color of the background, the text and the boarder color and kind, but it will not let me change the words. I tried highlighting, deleting backspacing it remains.   If donors submit forms with errors such as missing data, then error messages appear here.
    Oh I see what you're talking about. I don't believe we can change that text.
  • Thank you for trying to help - much appreciated
