Assigned Solicitor - clean up
I am trying to clean up old solicitor information.
Is it RE best practice to keep the "former solicitor" in the relationship tab?
If so, can you delete assignments from the solicitor's RE record and not change the relationship tab? Or do you have to change the relationship tab first - to Former and then delete the assignments?
Thank you!
Thank you!
I also wanted to clean up old solicitor info last year - specifically solicitor type table. Figuring that the moment I deleted it someone would ask "Who was the solicitor for ABC when we ran our capital campaign in 2008? so I just did some editing. For us, I determined best practice was to keep it on the relationship tab.
I went to the table and changed by old types to "Archive Info.." Created two archive types - one for capital and one for annual. We use From and To dates so that info is still present. Then using a tip from John H, I changed legend so that all past solicitor relationships appear in a gray.
If you delete the assignment on the solicitor's record it will delete the relationship.0 -
Michaela Walker:
Thank you!Moved to Raiser's Edge forums. Thanks!
Michaela Walker:
Thank you!0
