Stag [[S542:fr_ID:goal]] keeps giving me $0.00 for goal.
I'm trying to pull in the goal dollar amount from a personal fundraising campaign and am using the [[S542:fr_ID:goal]] tag but no matter what campaign I target the goal always comes up as $0.00. I've tried this with multiple campaigns and get the same result. All the campaigns I've tried are open so I can't think of any reason for the goal to display 0. Can anybody give me any info as to why this may be occuring? Thanks
  • Dylan Davenport:
    Could you share an example page for one of the fundraisers?
  • Jeremy Reynolds:
    Dylan Davenport:
    Here is an example of the page http://support.operationsmile.org/site/TR/Events/DonationPages?pxfid=27170&fr_id=1030&pg=fund
    Basically I have a custom thermometer and I'm using this Stag [[S542:1770:dollars]]  to fill up the thermometer's percentage using the dollar amount.
    What I need is to pull out the dollar amount and the goal separately and display it next to the thermometer. So far only this dollar parameter shows any results.
  • Dylan Davenport:
    Jeremy Reynolds:
    Dylan Davenport:
    Hey Dylan,
    Was just curious about this. I took a look at your example, and see both dollar and goal display in text below the thermometer. Were you able to resolve your issue?
    I can't help with the s-tag implementation, but if it worked, I might save this solution for the future -- in case we want to do something similar.
    Jason
  • Jason Thomas:
    Dylan Davenport:
    Jeremy Reynolds:
    Dylan Davenport:
    Hey Dylan,
    Jason
    Oh no that is text that I had coded in myself. My plan was to target those two elements in the HTML and use Javascript to insert the dollar and goal amounts there using the info that the Stag gives me. Only problem is the Stags I've used won't give me the info I need haha.
