Hubspot
Can anyone tell if they use HubSpot with RE and the pros and cons they have run into with using it. Anything you can share with me would be great.
Thanks
  • Hi Nancy,
    We use HubSpot and we use RE but they are not connected in any way
    We export lists from RE and import into HubSpot and once a month I export from HubSpot people who opted out of receiving emails to update RE with that information
    The pro of using HubSpot is it is more robust in terms of design for our Communications department.
    Cons is they are not connected
  • Thank
    you, does Blackbaud have anything that compares to
    HubSpot?
    Nancy
    Hegdahl
    Donor
    Records and Accounting Administrative Assistant
    United
    Theological Seminary of the Twin Cities
    3000
    5th Street NW
    New
    Brighton, MN 55112
    651-255-6110
    nhegdahl@unitedseminary.edu
  • Nancy Hegdahl:
    Thank you, does Blackbaud have anything that compares to HubSpot?
    Do you mean like using the email functionality in Luminate or NetCommunity?
    Or what are you needing HubSpot for?  I'm assuming email as that is all we use it for
    In any case I've used both Luminate and NetCommunity for email blasts and my experience has been the following:
    1. Hard to design an email as there is this background HTML coding that happens that screws up the format
    2. Because of the HTML - or it could be other reasons - there seems to be a higher number of emails getting stuck in SPAM filters
  • Thank
    you for this information.
    Nancy
    Hegdahl
    Donor
    United
    3000
    5th Street NW
    New
    Brighton, MN 55112
    651-255-6110
