Duplicate data on Report
I am hoping someone can help me with this. I have a custom report done with Crystal Reports that is a gift log. It is grouped by constituent and the detail is the gift record(s).
I use the following formula to display fund details:
{CnGf_1Fnds_1.CnGf_1Fnds_1_Description} & " (" & {CnGf_1Fnds_1.CnGf_1Fnds_1_Fund_ID} & ")" & if ({CnGf_1.CnGf_1_Amount} = {CnGf_1Fnds_1.CnGf_1Fnds_1_Amount}) then "" else (" - " & {CnGf_1Fnds_1.CnGf_1Fnds_1_Amount})
This works fine unless it is a split gift, when it duplicates the information displayed. For example:
Fund Description A - $1,000.00
Fund Description B - $1,000.00
I have tried suppressing duplicates without success.
I also display soft credits using this formula:
{CnGf_1SfCrdt_1.CnGf_1SfCrdt_1_Constit_Name} & " (" & {CnGf_1SfCrdt_1.CnGf_1SfCrdt_1_Constit_ID} & ")"
This works fine unless there is more than one soft credit recipient, and then it only displays one (the second one on the gift record).
Thanks so much!
Shaun
You'll need to put your fund information in a subreport within the details section. You'll probably need to do the same thing with soft credits.0
Joshua Bekerman bCLO,:
You'll need to put your fund information in a subreport within the details section. You'll probably need to do the same thing with soft credits.Thanks Josh, I had a feeling I would have have to do that. Was hoping there was another way!
Shaun
Shaun Grace:
Hi,
Thanks so much!
ShaunThis is only one of the reasons we do not split gifts. When a donor changes installment dates on pledges when one pledge fund has one date and the other needs a different installment due date, it becomes confusing. We find it is better and more transparent to and enter them as 2 pledges, or 2 gifts or 2 payments.
