Error: Header row cannot end with ","
If you are attempting an upload of a CSV file, and when you click "Run Operation" you receive the error "Header Row cannot end with "," this may mean that Excel has placed an extra column of data in your CSV file. You can tell if you open the file in a text editor, like Notepad, and if you see a comma at the end of every row, Excel has placed an empty column in your document. To remedy the situation, you simply need to open the file in Excel, and select the first blank column, and delete it. Then save your CSV document, and upload it, you should not receive the error.
