Exporting Emails for a group from Luminate
Can someone let me know the best way to export a list of email address from Luminate for a particular interest group. Seems like that would be a simple thing. Please help.
We don't use interests yet as well as we should, but I know that one way to get a list of the constituents and their email addresses is to just use Data Management > Mail Merge. First choose the outputs you want, then you can choose to restrict it by your interest-related groups on the second step of the mail merge options.
If you don't see the right group there, it is possible the interest isn't configured to rebuild a group - you can fix that by setting up a Task to segment your interest respondees into a rebuilding group. You configure that here: Data Management > Tasks > Task List tab > Create a New Task > select "Interest Segmentation."
It is a bit clunky - maybe someone out there who uses interests more knows of a quicker way or maybe a Report Writer option? But this should get the job done in the meantime!0 -
I'd probably go with the mail merge too.
One thing to note is that when someone opts out of an interest, they are added to the opt-out group - but they are not removed from the opt-in group. There are older threads about some problems that this causes people.
So you would have to pull the addresses for the interest opt-in group, and then you would need to remove those that appear in the interest opt-out group.0
