conditional code to make wrapper content appear/not appear in Donation forms
I use some conditional code to make content appear to users only when on donations Classic forms, but it doesn't work for Donations 2.0. Does anyone know the code that I'd use to do this with Donations 2.0? Here's what I use for Classic:
]x::
Displays when on donation pages
Displays when NOT on the donation form
Did you just copy it, or did you try using the component drops down to recreate it? Can't imagine why it would not work, but sometimes copying stuff to and from the WYSIWIG editor does not always work so well.
Also when you post code, to the forum, its best to do it using code formating.... if you click the ? icon in the editor, it will show you all the possibilities -- but what you want is to use code in brackets around the actual code...
(as above but without the \\s... i couldn't figure out how else to get it to display.
The application id for Donation2 is 9. Your code should look like this:
DavidHart :
Thanks, Dave for the quick and accurate response!!
I've got another question for you.... our Google Analytics funnels aren't working with Donations 2.0 and we're not able to distinguish between the form page and the thank you page. Any special trick to make this work for us?
Thanks
Michelle
