Listing membership benefits in OLX
We're new to OLX and we're trying to list membership benefits in the template. It will not allow us to use bullets, dashes, etc. It puts everything in paragraph form which is tough for the customer to read. It would be much better if we could list each benefit under each category on a separate line.
Hey there!
I have often found that keyboard shortcuts for symbols work well in the case you are describing. For example, if you want to enter a bullet, on a mac keyboard press alt and 8 at the same time. Or if you don't want a paragraph break every time you hit enter, at the end of your line press shift and enter at the same time. If you are using a windows computer, it may be slightly different for both of these, but you should be able to google keyboard shortcuts for these actions.
I think this is what you are describing as the problem, but I may be reading it wrong. Let me know if that helps!
Thanks Tracey...Unfortunately that did not work. Hoping something can be done soon.0
