Deleting offline donations added via SRTeamraiser addGift
has anyone any experience removing offline gifts that were added using SRTeamraiser addGift?
The deleteGift method is only CRTeamraiser so that is a no go for server side work.
Can’t imagine requesting that participants clean up the work of a rogue script.
  • Are you really just trying to clean up an error, or build something ongoing?
    If it's just cleanup, I use Excel hyperlinks for this sort of task. Build a report of all the transactions you want to delete and be sure to include the transaction Id.
    Now check out the URL of the dialog pop-up when you actually delete one:
    https://secure3.convio.net/abc/admin/TransactionAdmin?pop=t&actId=del_tr_gift&tx_id=1016452&pg=action
    You can add a column with a formula that creates hyperlinks just like this, putting each row's transaction id in the url.
    =HYPERLINK(CONTATINATE("https://secure3.convio.net/abc/admin/TransactionAdmin?pop=t&actId=del_tr_gift&tx_id=", B2, "&pg=action"), "delete me")
    Fill that formula down and your all set. Then you just run down the list, clicking the link and then hitting submit on the opened page. I can get through 100 of these in 10 minutes or so this way. Same idea works for soft credits too.
