Crystal Report Totals
IF {CnApls_4.CnApls_4_Package} = "Splash - Live Auction Donation"
Then {CnApls_4.CnApls_4_Total_Given}
else IF {CnApls_4.CnApls_4_Package} = "Splash - Silent Auction Donation"
else 0
In the details it will duplicate the totals if they have other packages. If I sum the group for the records that truly have 2 appeals it calculates correctly. But for the records that duplicated the details it adds each of the duplcated lines. For example JB has 2 gifts $1 + $5000 = $5001. HG has 1 gift (that should be included) of $6800 but the details displays it four times so the sum is $27,200. So I thought I would use running totals.
Feild to summarize (appeal total given - based on my forumla above)
Evaluate on change of field (I selected the Appeal ID KEY)
Reset on group name
JB calculates correctly. DG calculates incorrectly as $27,200
If I change it to evaluate on change of group (I selected name) JB only calculates $1 but HG calculates correctly.
Help?
If I am understanding this correctly, I think you need a separate formula for each donation type. Then sum each donation type. Then get the total of each summary for the grand total.
I have a seperate formula for each appeal looking at the packages and a seperate running total. For each seperate year the appeal could have say 6 different packages. I only care about 2 of them. Most donors only have 1. JB has both of the packages that I am interested in. DG has 1 that I am interested in and 3 that I am not.
Do they have donations for the packages that you are not interested in? If they would not and the value is zero, then it would not matter. 5000 + 0 + 0 + 250 + 0
I hope I'm not missing something. Whatever you do, it must be a formula and total that will be applicable for everyone. Your individual formulas must be something like this - not grouped together:
Formula Sp_LAD: IF {CnApls_4.CnApls_4_Package} = "Splash - Live Auction Donation"
Then {CnApls_4.CnApls_4_Total_Given} else 0;
Formula Sp_SAD: IF {CnApls_4.CnApls_4_Package} = "Splash - Silent Auction Donation"
Do this for each donation type, then add them all together. Sorry, if I'm missing what you are trying to do.0 -
Chester Bammel:
Do this for each donation type, then add them all together. Sorry, if I'm missing what you are trying to do.the packages I am not interested in do have amounts. Just curious why the formula can't be grouped together?
Okay, I think it is finally sinking in. Sorry, sometimes it takes a bit to get your head wrapped around it. So, the real question I think is why are you getting multiple detail lines for each formula? Why would one person have 1 line, another have 2 and another 4? There is something there that is causing the repeats. There should only be a single detail line with each of the totals on it.
I can suppress the duplication of the details - but then I have to use running totals otherwise the sum will still calculate the hidden duplicated fields. I don't understand why the running totals will only calculate correctly if there is only 1 package that I actually want to see for the donor?
I could create a group for each appeal - but then the formatting would be wrong as I need it to be in 1 row for each donor. Unless there is a trick to make it display correctly?
Its a complicated report and I appreciate your quick response and trying to wrap your head around it and what my problem is!0
