Setting enter key in RE to tab to next field.
Is there a way to set the enter key in RE Batch Entry so that it will automatically tab to the next field? In FE if you hit Ctrl and the right arrow, the enter key will move to the next right field. This saves a tremendous amount of time when doing a lot of data entry in batches.
Darien Reinheimer:
Is there a way to set the enter key in RE Batch Entry so that it will automatically tab to the next field? In FE if you hit Ctrl and the right arrow, the enter key will move to the next right field. This saves a tremendous amount of time when doing a lot of data entry in batches.Unfortunately, not that I'm aware of. Of course the actual 'tab' key can do this, but I imagine you're trying to set somethere up where you can focus pretty much solely on the number pad. If that's the case, you can buy an auxiliary number pad that includes a tab key for exactly this kind of setup.
