NXT feature that shows locations of nearby donors?
Hi Community,
I recall an NXT function wherein if you enter an address, a map will display with pins indicating others donor addressess in that geographic area.  I can't seem to locate that feature now though.  Can anyone share with me how to navigate to it? Thank you and happy EoY!
-- Matthew Patchell
  • Matthew,
    When you are in a work center for a fundraiser, click on the portfolio tab and then the filter button.  In the filter, click on location and filter using map view.
    Brandon
  • Brandon Stein:
    Matthew,
    Brandon
    Brandon, awesome, thank you so much for your quick and helpful response.
    Community: this is a killer feature, a huge time saver for gifts officers in the field making donor visits.  Gift officers, check it out.  If you are not a gift officer, do consider sharing it with yours.  The feature enables you to see where on a map your donors are located.  So once I have one scheduled, I can work on filling my schedule with others in the same area.  Thanks to this tool I found several donors in the same BUILDING!
