Trouble displaying a scrolling status indicator on TeamRasier greeting page
I figured this out.... but now I can't figure out how to delete this message from the Community board.. .. so I'm just posting my solution in case anyone else runs across this.
In working to customize the Greeting page in TeamRaiser, if you choose to use the built in layout options in the dropdown at the top, the status indicators will display and work just fine (but you have no control over WHERE they are). If you simply disable that and use the "No buttons/No status indicators" layout, then you can drop in the following code to pull in the scrollers anywhere on the page that you'd like them to appear:
Sample Code Example of adding an honor roll to a PageBuilder page where the Teamraiser's ID is 1040:
S Tag Input:
Because the team_id and cons_id are unknown, "0" makes a call for all teams and all cons within the TeamRaiser.
Convio Tags Input:
<convio:session name="36" param=" top_teams_list,1040,0,0,SCROLLING,SUM,100,TOP TEAMS " />
Hope this helps.
Jon
Message was edited by: Jon Reich
