use conditional to change thank you page
How would you use a conditional to change the message on the Thank You page, so it is customized for one time and monthly donors? I tried by Donor and by Group, wasn't successful with either -
There is an S120 tag that allows you to get access to alot of donation information. This is the tag used for the transaction summary. You may want to see if there is a parameter that you could use to pull the recurring gift information that is present for a sustaining gift but is not present for a one time donor. If you can find this you might then be able to use this to conditionalize the thank you page based off of one time vs sustaining gifts. This would likely require alot of testing to get it to work exactly as you wish but I think it may work.
-Andrew
Andrew :
-Andrew
I am struggling with the same problem. I have found an S120 tag that seems like is should work, however, when put to the test it not only does not work but it says "no such property: recurringBaseAmount". Any feedback on this matter would be appreciated. All I am trying to do is acknowledge the monthly giving amounts in a conditional in contrast to one time donation amounts on the Donation Thank You page.
Best regards,
~Tonya
TFudge :
Best regards,
~Tonya
This should do the trick:
]x:
ne time gift:
ustaining gift]]
