Querying Primary Email
For example, when we send email through NetCommunity, we used to be able to run a query to find NetCommunity email bounces (BTW, that part is broken too with a Spring 2018 fix :-O ) and then globally change them to "Bad Email". BUT they are still marked as Primary in RE . . . so when we email to Primary, it is pulling "Bad Email".
So I wanted to run a query . . to see how many "Bad Email" types I have that were also marked as "Primary". Well, you can't do that. the "Is Primary" box in query only searches for phones, not emails.
That seems to be a significant oversight . . . and is problematic.
Now, we ran the "Mark phone as primary" plugin in reverse . . and applied it to ALL "bad email" . . . but I still am flumuxxed as to why that wouldn't be a feature to query on.
Anyone have any thoughts?
Try using Export, which should help. Although you may then need to copy-and-paste a list of ConstIDs back into a Query.
The Primary and Inactive (and DNC) Phone Fields all function the same, and they are not directly tied (in Query) to a specific Phone Record. This is why, at my last org, we kept our setup of using different Phone Types ("xHome" with a comment indicates an Inactive Phone). The Phone Comment Field is directly tied to the Phone Record. The other piece that this solved (for me) is that the [Show Inactive Phones] checkbox is not necessary...and since it's not sticky, I found it confusing/difficult.2 -
Brian Bates:
It is a little misleading that the field names in query all start with Phone, e.g. Phone Comments, Phone Inactive, Phone Is Primary? They actually include phones, emails, links, fax and other.3 -
Jen - So what good is it to have a phone number/email marked primary but yet in query, export you can't use that data? I don't get it ...
Seems like it's only good visually when you open the record but no good for anything else ?
Jen Claudy:
The Primary and Inactive (and DNC) Phone Fields all function the same, and they are not directly tied (in Query) to a specific Phone Record. This is why, at my last org, we kept our setup of using different Phone Types ("xHome" with a comment indicates an Inactive Phone). The Phone Comment Field is directly tied to the Phone Record. The other piece that this solved (for me) is that the [Show Inactive Phones] checkbox is not necessary...and since it's not sticky, I found it confusing/difficult.0 -
Gina, exactly why I kept our Phone Type system and didn't bother with the Inactive and Primary checkboxes.
Love the Phone Comment Field, though.2 -
Gina Gerhard:
Seems like it's only good visually when you open the record but no good for anything else ?4 -
I believe once you select a Primary and [Save and Close], the next time you open the record, the Primary will be at the top of the Phone Grid (and the Inactives will be hidden altogether).0
Jen Claudy:
The Primary and Inactive (and DNC) Phone Fields all function the same, and they are not directly tied (in Query) to a specific Phone Record. This is why, at my last org, we kept our setup of using different Phone Types ("xHome" with a comment indicates an Inactive Phone). The Phone Comment Field is directly tied to the Phone Record. The other piece that this solved (for me) is that the [Show Inactive Phones] checkbox is not necessary...and since it's not sticky, I found it confusing/difficult.Thanks . . but regarding comments, those don't flow through to NXT. So you say all sorts of fun things in DB regarding why a phone is there, but if someone is only using NXT to access records, the information is not there . . . any plans to include notes in NXT?
And I was able to get the info I needed by NOT selecting the specifiic phone type, but using the generic phone type and setting it to = the specific phone type + primary and gave me the results I needed.
Go to the NXT Idea Bank and vote for this Idea...and also this Idea and this Idea. (It could probably be a full time job for someone to find & merge duplicate Ideas.
Jen Claudy:
Go to the NXT Idea Bank and vote for this Idea...and also this Idea and this Idea. (It could probably be a full time job for someone to find & merge duplicate Ideas.)
Well . . . I posted the last idea, thought I searched for the keywords and missed the others . . . and don't they have the ability to merge ideas? Seems like a good idea!
