How can I mass delete info from a field in multiple constituent records?
I need to delete a mistake that was made in a field, during an import, in multiple records.
you can update, but you cannot (by yourself) blank out any field. you will need to ask support to do that for you. I know, i've been there.
Andy
Can you pass it a space " "? If it needs to be null or empty then support will have to help you
Ryan Hagg:
hmmm, I never tried to use space " ", as the fields I wanted to blank out were date-type. i am sure you can, though. just do a test on 1 record and you'll find out
I personally dont like " " as it will change the query logic. a space would be considered a value so you couldnt do clause "where field is blank", instead you would have to do "where field is equal to " "". it wont be easy to maintain for the long run.
Andy
