Inserting images into an OLX thank you emai?
Is there a way to insert an image into the Online Express Thank You email on the Thank You's tab? I want to put our CEO's electronic signature, as well as our organization's logos in to make it look more polished, but all I can insert is merge fields, special characters and a link.
  • Dedra Devereaux:
    I haven't seen one yet, but I'd be interested in knowing if it's possible, or if someone has found a workaround, as well.  Or even a way to use the Templates we set up in the email module?
  • I just watched a webinar with OEX expert Grace Tate.  She said you could only insert images that are already online somewhere in public pages.  To insert an image, find it online, right click-> Copy, and then on your thank you letter you can right click and Paste.
  • Christel Tatro:
    I tried that with no luck. there is no way to right click into the edit email area, or you can right click, but nothing happens.
  • Even if you can't right-click, you CAN Ctrl-V, which will paste the image without having to right-click.  Try that, and see if it does the trick.  I haven't had a chance to double-check it this morning, but it should work.
  • This worked for me earlier this year, but trying it today, I couldn't get the image to paste in. Even with control + v.
    Any one else experiencing this?
