How to keep the Event Unit data table from getting out of control
We are a large healthcare orgnaization, with multiple hospitals each doing 1-2 events per year. We have one centralized RE database, and I have found that our "Event Units" data table is out of control.  Several reasons:
1) The name of the sponsorship levels change based on the theme of the event. For example, the $2,500 sponsorship one year is called "Ruby Sponsor" and the next year "Crusader Sponsor".
2) The sponsorship levels might increase.  For example, the "$2,500 Sponsor" one year is "$3,000 Sponsor" the next year.
3) Clearly, as you can see from #1 and #2, we bounce between named sponsorships and amount sponsorships in RE.
4) The data table is not ordered by alpha, because... as it is now, when new units are added for a particular event, we have found it beneficial to keep the levels for that event together. Mainly because the data table is so long, and it's hard to filter queries/exports/reports with such a long data table.
How does your organization use the Event Unit data table? How do you keep it organized? How do you rein it in??
  • Julie Hiland:
    Not sure why this posted under the OLX category. I have re-posted under Optional Modules.
  • Julie Hiland:
    Hi Julie,
    I experienced the same thing when I inherited my current database. I went through all of the past event units and made the one-time registration types Inactive. You can do this under Configuration - Tables - Event. It does mean that you will need to do the clean-up after each event, but it will keep things under control moving forward.
    I also have a couple of Event units that I have given generic names to - ie. Ticket, Table that I am able to use over and over. I simply update the unit prices from one event to the next.
  • Julie Hiland:
    Hi Julie,
    I have also experienced this when I took over our database. I went through all of the tables under configuration and made many of the entries Inactive. We made more general table entries going forward. For example, instead of $2,500 Ruby Sponsor, we said $2,500 sponsorship, that way it can be used from year to year in RE and it's based on dollar amount instead of a specific name.
    Amanda
