How to use HTML formatting on a Multiple Choice Single Response (Radio) survey question?
I need to use HTML formatting on the Question Text and Possible Responses for a Multiple Choice Single Response (Radio) survey question. I'm not seeing a way to do this. Can anyone help?
Jill,
Not sure what you're trying to do exactly, but you do not have access to edit the underlying HTML rendered by the Survey application*. Can you describe what you're attempting to do in a bit more detail? Perhaps it's possible you can achieve your end goal just by using CSS?
*Note that it is possible to edit the HTML of a Survey by copying and pasting the raw HTML of the form into a PageBuilder page. See http://community.customer.convio.com/docs/DOC-2117 for more info on that technique.
