Search by constiuent ID in a Query
Hi All,
When attempting to run a query, I want to use "one of", and then enter the constituent ID.  However, I am finding that when I enter say, 263, Raiser'sEdge doesn't select just record #263.  It chooses several records that contain the number 263.  How can I have it select 263?  I have this problem when the ID number is short, fewer than 6 digits or so.
Thank you,
Teresa
«1
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    I'm running version 7.93 and when I create a Constituent Query with criteria of "Constituent ID one of 263" my system returns only the one record where the ID = 263.  I don't get ID = 1263 or 26345, just like you're expecting to get, so I'm not sure why you're getting different results.
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    Hi Teresa,
    You would use equals 263.  The one of will give you anything with 263 in it.  The equals will only give you 263.
    Patti Posey
    Stamford Hospital Foundation
  • I know about equals, but I want to search for
    several records, one of them being 263.
  • Patti Posey:
    Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    Hi Teresa,
    Patti Posey
    "Like" would give you anything with 263 in it.  "One of" should not.
  • Are you using “one of” or “equals”?  I
    want to search for several, so I’ll use “one of”, but when some of
    the IDs are just a few digits long, RE selects more than just the
    263.
  • I know about “equals”, but I want to use “one
    of” so that I can search for several at once.  I want to know
    if there’s a way to basically do an “equals” within a “one of”.
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    Teresa, could you post a grab of the query criteria? I can't replicate this either. My criteria (Sample DB) are:
    ad3495780dc93e5059fdfa9808351daf-huge-27
    Results, as expected, are:
    2a19743303271c21a405bbb9602bad2e-huge-27
    Steve
  • I've just tested this on both 7.93 and on our 7.96 pre-production system and couldn't replicate it on either. I even tried with *, ? and % wildcards and it still only included the records that were an exact match.
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    I couldn't replicate it either. When you are copying from excel, could it have to do with the formatting of the cells?
  • Hi
    I tried it
    on mine and I chose Constituent ID – EQUALS and typed in the ID
    number that way and it only brought up one.
    It’s the
    ‘one of’ that is throwing it off as you can have more than ‘one of’
    if that make sense.
    Good
    luck!
    One in two
    young women has experienced controlling behaviour in a
    relationship;
    more than a
    third of young people would not know where to turn for
    support.
    Watch and
    share
    BRIT-nominated
    singer-songwriter Frances and Refuge’s new music video, which tells
    young women: you are not alone.
    Carol
    Hanchett
    Database and digital senior executive
    t: 020 7395 7760
    Visit www.refuge.org.uk to set up a direct debit
    and sign up to a running event or our annual
    newsletter
    Text 'REFU40 £5' to 70070 today to give Refuge a £5
    donation
    Follow Refuge on Twitter
    Like Refuge on Facebook
    The information in this email and any attachments thereto is
    confidential. If you are not the intended recipient, you must not
    read, use, copy or disseminate that information. If you have
    received this email in error, please notify the sender and destroy
    it immediately. It is your responsibility to protect your system
    from viruses and any other harmful code or device. We try to
    eliminate them from emails and attachments; but we accept no
    liability for any which remain. We may monitor or access any or all
    emails sent to us
    in
    accordance with applicable law and
    regulations.
    Refuge
    is a registered charity number 277424 and a company limited by
    guarantee, incorporated in England and Wales, with registered
    number 1412276 and registered office at International House, 1 St
    Katharine's Way, London E1W 1UN
    .Further
    information is available from www.refuge.org.uk
  • That’s great!  Did you use “equals” or
    “one of”?
    If I use “equals”, I get just the one record,
    but I want to use “one of”, and when I do, I want to receive each
    of the records as I entered them.  For instance I want 46718,
    65725, and 623.  I don’t want all records that include the
    sequence 623 - 623, 62348, 6234, etc.
    Thank you,
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    3801 W. Temple Avenue
    Pomona, CA  91768
    (909) 869-2969
  • I’m not copying from Excel, I’m entering the
    numbers manually.  Is it possible to copy from Excel and not
    have the issue?
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
  • Yes,
    it works fine if I choose EQUALS, but then I can only choose one
    record.  I know it’s the “one of” that’s throwing it off, but
    it shouldn’t because I don’t have more than one of any particular
    constituent number.  I want it to give me only the record for
    the number I enter, not all records that contain that sequence of
    numbers in their IDs.
  • I never had the issue either way, so if it is a Raisers Edge bug it will not help you, but you can certainly try and copy -up to 500 records- from excel into the query.
    Choose Constituent ID is one of - then scroll all the way down, click into the last cell, Ctrl-V, scroll back up and they should be there.
  • Teresa Hosch:
    Yes, it works fine if I choose EQUALS, but then I can only choose one record.  I know it’s the “one of” that’s throwing it off, but it shouldn’t because I don’t have more than one of any particular constituent number.  I want it to give me only the record for the number I enter, not all records that contain that sequence of numbers in their IDs.
    You really need to reach out to support on this. What you're experiencing is not expected. If what you're describing is actually happening, then there's a bug that we're not going to be able to identify as a community. "One of" should only find exact matches to the field of parameters. What you're describing is what you'd expect from a "contains one of" operator, which off the top of my head I don't think actually exists in RE (running an export right now so I can't verify).
    To answer one of your other questions though, you can indeed copy/paste from a list within Excel.
    1.) copy the list
    2.) Select your 'one of' operator
    3.) Scroll all the way to the bottom of the possible "one of" fields (all fields are empty at this point
    4.) Click on the very last field (I know this is sounding unituitive - that's because it's unintuitive)
    5.) Cntrl+V to paste in your list
    6.) Even if you don't see anything change, hit "ok" and all of your values will be there
    Note: There's a limit of 500 options for any "one of" operator, so if you have more than 500 items in your list, you'll need to string together multiple 'one of' criteria as OR statements.
  • I did reach out to Blackbaud, and was told
    that what I want to do cannot be done.  It’s difficult to
    believe that our institution is the only one that wants this
    capability, so I reached out to the community.  It sounds like
    others want it, but have it, so I’ll keep working to get it to work
    for us.
    Thank you for the suggestion regarding
    Excel.  Others, too, mentioned that, and I will definitely
    give it a try.
    Thank you!
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
  • Have you tried choosing 'specific record id' instead of constituent id one of
  • Jenny Physioc:
    Or when entering the constituent id having the box checked for Exact match
  • I’m working in Query where there is no
    “specific record ID” and no “exact match” box.
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
  • Teresa Hosch:
    I did reach out to Blackbaud, and was told that what I want to do cannot be done.  It’s difficult to believe that our institution is the only one that wants this capability, so I reached out to the community.  It sounds like others want it, but have it, so I’ll keep working to get it to work for us.
    Thank you for the suggestion regarding Excel.  Others, too, mentioned that, and I will definitely give it a try.
    Thank you!
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
    "Cannot be done"????  But you see that others are doing exactly that, unless there's something else you told Blackbaud that you're trying to do that you're not telling us in the community.
    The behavior you're describing is not what others are experiencing (no one else here gets the same results you say you get with a Query using the criteria you've described).  If the community has all the same information you gave to Blackbaud then your RE is not behaving as designed and you have discovered a bug that should be documented and fixed.  There should be no reason that this "cannot be done."
  • In query under Constituent Information
    ​choose Specific Record or Constituent ID
    ​Choose One of
    ​search (click on binoculars) and your search window appears
    check the exact match box then start entering your number
    ​You do have to search after each entry but it does work.
    I used to do it this way until I started using SmartPaste.
    ​I think it would be quicker to type all of your numbers in Excel under one column then copy and
    paste them back in using SmartPaste.
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    I actually didn't read all of the responses so my apologies if I'm being repetitive. Instead of using constituent ID have you tried a Specific Record query? Specific Record one of....and you can select each constituent instead of usind an ID.
  • Teresa Hosch:
    Hi All,
    Thank you,
    Teresa
    Could you use the parentheses function in the query criteria to say "(equals 263) OR (one of...for the other constituents you want to find)"?  That might eliminate the multiples with 263 in them, by segregating the 263 search criteria from the rest of the search criteria, if you're not having problems with the rest of the criteria results.
    I do this a lot with names, where I'm pulling specific students' parents but my list includes a common last name.  I add the first name to that last name criteria and put them in a parenthesis with an "AND" operator.
  • Wow! I didn't know that. I just trusted what the support rep told me ages ago and never experimented. Thanks! :)
  • No problem :)
  • John Heizer:
    Teresa Hosch:
    Thank you!
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
    I can replicate this behavior in my database and I have a guess as to why others aren't able to.
    The database I am working in has lived through several differernt ID schemes. So really old records have 3 or 4 digits and newer ones have 9 digits. Others have TB or TBN at the start of the ID.  If the database stuck to one scheme, then this quirk would not appear until you "turned off the odometer."
    A similar thing happens in my database when I sort by ConsID in a query; It seems to behave as if the ConsID field is text irather than numerical (it's early and I'm at home without access to RE, so I apologize if I just wrote something stupid about the field).
  • Apologies if my"reply to this post" shows up in the wrong place.  I find the formatting confusing.....
    However, I wanted to add my thought about formatting ID numbers.  We have 7-digit IDs, and if it is an older ID, it may have leading zeros, and that must be considered when querying on one or many IDs.  I have no trouble using "one of" and pasting in an excel list - but those leading zeros are required or RE doesn't find them.
    John Zajc
    John Heizer:
    Teresa Hosch:
    Thank you!
    Teresa Hosch
    Prospect Researcher
    Cal Poly Pomona
    Pomona, CA  91768
    (909) 869-2969
