How do I set the minumum donation amount?
The minimum donation amount for Donations2 is set per donation form. It is set in the section where you configure donation levels.When you edit the Donor Entered Amount, you can, under the Gift Amount, set an amount that is the minimum that a donor can enter.
There is also a site data parameter that can be set by a support analyst that will work for Donations Classic. set an amount that tis the minimum that a donor can enter
