How would I create a query in Raiser's Edge for a Luminate Online welcome series?
We've developed a donor welcome series and new constiuent welcome series we would like to send out. Previously, we would build the queries in Luminate - now that have the RE/LO integration, how would we replicate those same queries in Raiser's Edge?
  • Sara Bruns:
    Depends on how you want to query. Assuming you wanted to make the query in RE and then use the results as an email sending group, you'd just save the query to a folder called "Luminate" within your RE instance. Once that's done, you can go into LO's Constituent 360 and click the green "Map a new group to an offline segment," and you should see a list of all your saved RE queries in the dropdown (just above rebuilding options).
    Finalize the group's name, security settings, rebuilding options, etc. From there, you'll follow the same workflow as normal to send the message, adding the RE-generated data to your campaign as a delivery group.
  • I'm semi-familiar with RE fields. I need to figure out the
    corresponding RE fields for the following Luminate
    fields:
    System
    creation date falls on or before 1 day prior to
    today
    AND System
    creation time falls on or after 7 days prior to
    today
    AND not a
    member of [existing query name]
    AND System
    Donor Status equals non-donor
    I’m guessing System Creation Date in
    Luminate is the same as Constituent > Date Added in RE, but I
    don’t know where to finfd “Donor Status” in RE?
    Sara Bruns
    Online Fundraising Manager
    Conquer Cancer Foundation of the American
    Society of Clinical Oncology
    2318 Mill Road, Suite 800
    Alexandria, VA 22314
    571-483-1453
    conquer.org   • asco.org
    cancer.netcancerlinq.org
    Making a world
    of difference in cancer care
    Privacy Notice:
    The contents of this electronic message, including any prior
    messages, files, or attachments transmitted with it, are
    CONFIDENTIAL and are intended solely for the use of the
    individual(s) to whom the message is addressed. This message may
    contain legally protected or privileged information. Do not read,
    copy, disclose or forward this message without authorization from
    the originator of this message. If you have received this message
    in error, please notify the sender immediately and delete all
    copies from your system.
