LO-CRM Connector
Bill
We use LO and RE with the RELO connector - if this is similar to what you have let me know and we can certinaly discuss and compare notes.0
Hi Dennis:
Thanks for your response. I don't know if the RELO connector is configured in the same way as on CRM. Our problems have to do with using existing audit tools in the CRM application and directly with SQL to determine when/what data is modified and by whom.
Bill0 -
Hi Bill.
We also use the BBCRM à LO connector and have significant
challenges too. I’m curious as to what inappropriate data
modifications you are seeing. Perhaps they are similar to what we
face on a daily basis and perhaps if we band together, BB will fix
their connector.Looking forward to hearing more!
Jen
Jennifer Gareis
Application Business Analyst
Second Harvest Heartland | 1140 Gervais
Ave., St. Paul, MN 55109
Direct: 651.209.7969
Mobile: 651.235.5837
Fax: 651.484.1064
Ending hunger through community partnerships.
The information in this communication, including all attachments,
is privileged and strictly confidential. It is intended solely for
use of the individual or entity named above. If the reader of this
message is not the intended recipient, or the employee or agent of
the recipient, please notify the sender immediately and delete this
communication from all data storage devices and destroy all hard
copies in paper format. Any unauthorized dissemination,
distribution, copying or other use of the information contained in
this communication is strictly prohibited.0 -
Hi Jennifer:
I'm sorry that you are also having grief with the connector.
With our initial CRM to LO synchronization we had many instances where primary flags for addresses, email, and phone were changed from a business address to a home address. Subsequent clean up and a connector "fix" were needed.
After a global change to address info for deceased records the connector removed all deceased info from approx. 70 records.
As you can imagine we are now proceeding tentatively with connector. The "out of the can" audit report on CRM is not effective for examining multiple records quickly. Blackbaud is still working on a full fix but it has been slow and painful. We are also seeing repetitive constituent demographic data exceptions and "invalid sender email" errors. Sorry for the barrage!
Bill
This electronic message is intended to be for the use only of the named recipient, and may contain information that is confidential or privileged. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or use of the contents of this message is strictly prohibited. If you have received this message in error or are not the named recipient, please notify us immediately by contacting the sender at the electronic mail address noted above, and delete and destroy all copies of this message. Thank you.
code:d34y
