Report on Appeals received
I need a query of the constituents that received a certain appeal (not only the ones who donated to the appeal). I globally added the appeal to the records but cannot find a way to query on this info. I'm having trouble finding any answers regarding this process. Help!
thanks.
  • In a constituent query, if you expand the "Assigned Appeals" node, which is about half way down the list of criteria categories, you can then select appeal ID or description to add to the criteria.
  • Ooooh, now I see it. I didn't realize they are called "assigned appeals". Thanks so much!
  • If you need to look for the same information in an export, they're just called "appeals" there. Query is probably the only place you'll find them called "assigned appeals", as one example of RE very helpfully labelling the same thing with a different name in different areas laugh
