Pull Participant Center Uploaded image to elsewhere
<script>
jQuery(document).ready(function() {
jQuery.ajax({
url: 'https://secure2.convio.net/cco/site/TRC?px=[[S1:cons_id]]&pg=personal&fr_id=[[S80:trID]]&pgwrap=n',
dataType: "html",
success: function(data) {
var sSource = jQuery("#personal_page_image_div img", data).attr("src");
jQuery("#pulledimg").attr("src",sSource);
</script>
<img src="" id="pulledimg" width="285" height="400"/>
Is there a way to hit the TR personal page via SSL?
Or is there a way to simply grab the src of the #photo-thumbnail-example element (seem to be having trouble referencing it)?1
If you are embedding the image within PC context, you can use getParticipants API call that require auth token for logged in participant.
However, if you still want to resolve your CORS issue with jQuery request, you can try any proxy to pass accessing none HTTPS from HTTPS page. Below an example with YQL (Yahoo Query Language)$.getJSON(
'https://query.yahooapis.com/v1/public/yql',{
q: 'select * from html where url="http://convio.cancer.ca/site/TR?px=1663862&pg=personal&fr_id=22449&pgwrap=n" and xpath="//div[@id=\\'personal_page_image_div\\']/img"',
format: 'json'
}).done(function( data ) {
$("#pulledimg").attr("src",data.query.results.img['src']);
Romany Nassief:
format: 'json'
});Does getParticipants expsoe the image url?
Sorry, I mean getPersonalPhotos0
Hi All,
If I recall correctly in the past, that "getPersonalPhotos" API only pull uploaded photo of that logged-in person but can't be used to retrieve/display other people's photos. Furthermore the API itself need to be called with login session token (auth token) hence that was the reason why (as alternative) -- I was loading these personal pages into a DIV placeholder (through jQuery.load() + make sure you call the personal page TR URL sans pagewrapper through &pgwrap=n )
Here's actual implementation of the above mentioned -- that five honoree pictures that otherwise belongs to participants registered on different teamraisers on this landing page are pulled in that fashion.
http://main.diabetes.org/site/PageServer?pagename=FOTY_homepage
check from "View Source" following related function called loadFathers()
this implementation is within LO environment, but I think that could be displayed in an actual iframe if need to be rendered on different end cross domain since the iframe is just actually calling the pagebuilder page that does the jQuery.load() still within LO) -- that should likely address any CORS concern. Using a pagebuilder also gives flexibility if you want to call the page as a secure page or regular page since the URL used within jQuery.load for that page is relative.
Just a thought, but let see if that could be applicable to your needs.
regards,
Daniel
EDIT ADD ON:
Other tips (unrelated) on Personal Page you can call a teamraiser Personal Page in its secure URL counterpart by just adding "S" before the "TR" of the URL -- only if need be.
Example:
regular Teamraiser Personal Page URL:
http://main.diabetes.org/site/TR/StepOut/StepOutContent?px=1830701&pg=personal&fr_id=11524
If you are to add S before the T on that /TR/ portion, LO will automatically display the page using its https counterpart, and in this example our secure URL of that same page is:
https://donations.diabetes.org/site/STR/StepOut/StepOutContent?px=1830701&pg=personal&fr_id=11524
P.s. @Romany -- that YQL looks interesting; I'll probably need to explore that going further -- thanks for sharing the tips there!
Romany Nassief:
3 -
Hey there,
If you need this for the purposes of Open Graph head data, you could use <meta property="og:image" content="https://[[S29:SECURE_DOMAIN]]/[insert your shortname here][[E130:"[[C4:graphic_upload]]" ".." "" replaceall ]]" /> as the code in your meta area.
I typically use this as my code in the head when building out TeamRaiser sites:<!-- Begin Open Graph Content --> [[?x[[S334:pg]]x::xpersonalx::<meta name="og:title" content="[[E48:[[S42:0:fr-id]]:cons.first_name:screenname]] [[E48:[[S42:0:fr-id]]:cons.last_name:screenname]]'s [[E42:[[S42:0:fr-id]]:title:true]] Personal Fundraising Page" /><meta name="og:description" content="Please support me and donate to my page as I fundraise for the [[E42:[[S42:0:fr-id]]:title:true]] event" /><meta name="og:url" content="[[S8]]"><meta property="og:image" content="https://[[S29:SECURE_DOMAIN]]/[insert your shortname here][[E130:"[[C4:graphic_upload]]" ".." "" replaceall ]]" />::[[?x[[S334:pg]]x::xteamx::<meta name="og:title" content="Welcome to the [[E48:[[S334:fr_id]]-[[S1:cons_id]]:team-name]] [[E42:[[S42:0:fr-id]]:title:true]] Team Fundraising Page" /"><meta name="og:description" content="Join or Donate to the [[E48:[[S334:fr_id]]-[[S1:cons_id]]:team-name]] Team for the [[E42:[[S42:0:fr-id]]:title:true]] fundraising event" /"><meta name="og:url content="[[S8]]"><meta property="og:image" content="https://[[S29:SECURE_DOMAIN]]/[insert your shortname here][[E130:"[[C4:graphic_upload]]" ".." "" replaceall ]]" />::<meta name="og:title" content="[[E42:[[S42:0:fr-id]]:title:true]]"><meta name="og:description" content="A [[S0:SITE_NAME]] Peer-to-Peer Fundraising Event."><meta name="og:url" content="[[S8]]"><meta name="og:image" content="https://[[S29:SECURE_DOMAIN]]/[insert your shortname here]/images/content/pagebuilder/slide-1-[[?x1x9x::x[[S4]]x::[[S334:FR_ID]]::[[S42:0:fr-id]]]].jpg">]]]] <!-- End Open Graph Content -->This conditional says, if you are on the personal page then display the personal page image and content as Open Graph data, if not, then display team Open Graph image and data, then if not, then display this generic info (e.g. the slide on a greeting page for instance). You may want to give this a try.
I hope this provides you with a path to the image on a personal/team page to render it where needed when visiting a personal or team page.
Where it says, "[insert your shortname here]" in the code above, you want to replace that with your own Luminate Online shortname. It is in your URL just after the secure part of your domain when when logged in on the back end, (e.g. https://secure3.convio.net/[shortname is here]/...).
Will
Internet Solutions Consultant (Luminate Online Deployments)
will.hull@blackbaud.com1
