Web Service query operator similar to LIKE
I’m experimenting with a Luminate Web Services query, selecting Participants based on an EventID. My query looks like this:
select Participant from TeamRaiserRegistration where EventId = 1234 and Participant.ConsName.FirstName = ‘Ann’
That works just fine, but I need something like the typical SQL ‘LIKE’ operator in order to include variants of the name ‘Ann’ — Annabel, AnnMarie, Manny, whatever...matching the string anywhere in the field value, in a case insensitive manner.
In typical SQL my query would look like:
select Participant from TeamRaiserRegistration where EventId = 1234 and Participant.ConsName.FirstName LIKE ‘%Ann%’
This doesn’t work and I’ve found other references to CQL (Cassandra Query Language — is this what the web service query uses?) — that tell me something similar to LIKE doesn’t exist in this query language. The docs say the wildcard is
'*' | FIELD '*'
But using '*Ann*' does not work either.
I’m hoping I’m just missing it or there’s a workaround. Thanks in advance!
  • This isn't the full solution you're looking for but you may be able to essentially duplicate the functionality of LIKE 'Ann%' with:
    select Participant from TeamRaiserRegistration where EventId = 1234 and Participant.ConsName.FirstName >= ‘Ann’ and Participant.ConsName.FirstName < 'Ano'
    Not sure about LIKE '%Ann%' though.
  • Jerry Podhajsky:
    '*' | FIELD '*'
    One thing I'd note is that while the Web Services API does not support the LIKE operator, you can do what you're describing with the REST API getParticipants method which allows wildcards, e.g. first_name=Ann%.
    http://open.convio.com/api/#teamraiser_api.getParticipants_method.html
  • Jerry Podhajsky:
    '*' | FIELD '*'
    Oh, and CQL is "Convio Query Language". :)
  • Noah Cooper:
    Jerry Podhajsky:
    '*' | FIELD '*'
    Thanks for all responses. What I ended up doing is querying for all participants and teams for a specific eventId and storing that as a json array on the client. From there I can filter and sort on the client side. Works fine. This may not be a great solution long term, but for now the number of participants isn't so great that it causes a significant delay.
    I'm just getting up to speed with Convio/Luminate, so I will probably have many easy/dumb/obvious questions going forward...this is the first!
