Amounts
How are you creating journal entries with amounts that are partially deductible and non-deductible? Do you use the Received amount and non-deductible fields?
Example:
Sally is attending a Spring event and buys 2 tickets. Her total is $150.00, but $60 of that is non-deductible. We have been entering $150 for the received amount and $60 for the
non-deductible. However, when I run a query to find total deductible amounts the two fields are not subtracting, its only calculating the received amount field as a total.
Are we entering the date in wrong or is it a query issue?
  • Erin Perkins:
    Example:
    We entry our items that are partially deductible the same way. It may be the way the query is set up that results in the wrong information being returned.
    Mary
  • Erin Perkins:
    Example:
    Hi Erin,
    We enter our dinner tickets the same way. $110 in the received and $50 in the not deductible.  We only use the not deductible in the thank you tax letter.  So perhaps there is an issue with the query.
  • Erin Perkins:
    Example:
    Hi, Erin,
    This is a really good question. I've been working with non-deductible amounts too this year.
    I enter non-deductible amounts for our events in the very same way, with the received amount and non-deductible amount. The only time I noticed the deduction was on our annual contribution statements, in our "One Year Ago Received Minus Deductible Amount" field. I notice that same field when I build a report. Unfortunately, I didn't see that field in the query fields. Maybe a good next step is to use your query of one, Sally, to build a report with that aforementioned "Minus" field. That may give the deductible totals you are after.
    I hope this is helpful and not redundant.
    Have a great day!
    Tasha
  • Tasha Gibson:
    Erin Perkins:
    Example:
    Hi, Erin,
    Have a great day!
    Tasha
    Hi,
    We include the non-deductible in tax letters in a receipt statement along the lines of "the value of goods received in exchange for your donation is $X."  While you can't specifically query on the Received Minus Non Deductible amount, the field is available in reports. So depending on your end-game, you could work around by querying on Journal Entry Date, or the Event (however you track that) and then running a report from that query that will only give the deductible amount.  Hope that makes sense and helps!
  • Amy Holland:
    Tasha Gibson:
    Erin Perkins:
    Example:
    Hi, Erin,
    Have a great day!
    Tasha
    Hi,
    following this, We have come upon this situation also
    Thanks Ladies
  • I found some old information from 2013 that might help us all
    https://kb.blackbaud.com/articles/Article/65472
    hope this helps us all.
    Pam
