Can I change which "Contact Fields" are available, optional, and/or required for a given Action Alert?
The answer to this varies. If you are using a Convio created target (such as a Congressperson or the President), you cannot change those fields. If you have created your own custom target, you can change which fields are available, optional, and/or required in the "Select Contact Fields" step of configuring your Action Alert.
For more information on why certain fields are required when you using a Convio created target, click here.
For more information on why you cannot change the options in the "Title" field, click here.
