Field Names in uploading csv files
Does anyone know if you can have an "employer" field when uploading constituent info from a csv into Convio? I checked out the help page below and am not seeing anything.
http://help.convio.net/site/PageServer?pagename=Admin_Constituent_Data_Upload#constituent360_standard_fields
  • Hi Ben,
    You certainly can upload to the Employment fields. From your help link it looks like you're using the Standard Constituent Data Upload. In that case, the column headers would be as follows:
    EMPLOYER - Employer name, 255-character limit
    EMPLOYER_STREET1
    EMPLOYER_STREET2
    EMPLOYER_STREET3
    EMPLOYER_CITY
    EMPLOYER_STATEPROV
    EMPLOYER_ZIP
    EMPLOYER_COUNTRY
    EMPLOYER_INDUSTRY - Optional, can be used to identify employer industry or sector. 255-character limit.
    CONS_OCCUPATION - Optional, can be used to identify the constituent's line of work. 255-character limit.
    CONS_EMPLOYMENT_STATUS - Optional, can indicate whether constituent is presently employed. 255-character limit.
    POSITION - Optional, can be used to identify the constituent's position title at employer. 255-character limit.
    If you're using a Custom Constituent Import, you can title the column headers whatever you want, and use the dropdowns in the "Map Fields" step to assign these fields.
