bizarre OLX error message
I hope this one gets sorted before too long. Thank God I got my Giving Tuesday emails sent out yesterday and early today.
Just now when I try to load the OLX module in hosted RE, I get the following message. Furthermore, I am unable to edit constituent records and receive this message when I click to edit: "Automation error
Not enough storage is available to process this command"
But here's the OLX error message:
Error Loading Page from Shell
The Raiser's Edge was unable to load this page.
Please try accessing the page again. If you still encounter an error, Please note the following error and contact Blackbaud support.
Error Loading Page from Shell 'OnlineExpressPlugin.PluginHost'
Error number : -2147211486
Error description : 'General ODBC Error: [Microsoft][ODBC SQL Server Driver]Connection is busy with results for another hstmt
Native error:0
Native error:0
I would first log out of RE completely, then back in and see if you still get the error. Then I'd open a Support Chat. I think I've gotten that before, or something similar, and it didn't last too long or log out/in worked... If you find out what caused the error message, post the reason & solution here so others can maybe find it if they see that same error.
I was in OLX an hour ago, but right now, it's taking a while to load, so who knows, I might end up with that error myself. We're Hosted in Boston.2 -
Hi Mary! I created a support case for you so you should hear from someone soon. Just to help with some troubleshooting, what were you doing right before you tried to access the OLX plugin? Thank you!
Michele Stender
Associate Product Manager1 -
Thanks, Jen--
that did the trick!
I have never seen either of those messages before, so they were quite alarming.0 -
Michele Stender:
Michele Stender
Associate Product ManagerMichele--
Everything worked just now when I tried again, after logging out and back in again.
Before attempting to load the OLX module, I had been attempting to edit a consituent record.
Thanks Mary. Glad to hear it! Jen Claudy always knows the answer!
Please let us know if you see this error again in the future. I know you are busy today!1 -
Thanks so much, Michele--I will keep you posted!0
