Pulling email reports
I am looking to pull a report on every email message we sent out from July to today (with the message detail (sent, opened, clicks, etc)). From what I can see there's not an easy way to pull email reports by date so I thought I'd check here to see what best practices are or if any of you had any tips.
Thanks.
You can use the Report Writer Email reports to generate a report like this. Though an Email Campaign is required in the filter criteria, you can select more than one campaign at a time in the criteria. Select all the campaigns that might have messages sent in the date range you are evaluating. Then add Filter criteria for Send Started Date (found under Email Performance Statistics) for the date range you are evaluating.
I think you'll also find that the columns available on the Email Report Writer reports have the metrics you are looking to measure for each message.
Corey Pudhorodsky:
Does that mean Quick E-mails can't be pulled via Report Writer?
Michael :
Quick Email messages will show up in a Campaign called: "Ad Hoc Messages" If you want to select messages that were sent using Quick Emails, you can select that campaign.
