Query not appearing when trying Global Add
I am trying to do a Global Add for registration to an event for the first time. When the popup for Global Add comes up, I select "Registrants for an Event" and then "Include>Selected Individuals." Another popup opens where I can search for my query of constituent IDs, but it isn't listed. Does this box only pull up a certain list of queries? I searched for all dynamic individual queries and it only pulled up 25 different queries, and I know we have at least 10x that many.
Like I said this is the first time I have tried this so I must be missing a step somewhere. Any help would be appreciated (because entering registrants one by one is killing me slowly).
Kevin
  • Are you sure you created it as an individual query, and not a constituent query? I fall foul of that all the time; luckily you can just open the query again and change the type.
  • Your Query needs to be an Individual Query, not a Constituent Query.  In your Query, go to Tools > Query Options and change the Query Type from Constituent to Individual.  If this doesn't solve your problem, post again.  =)
    Also, you can tell this because in the Global Add search window, it shows you which Query Types you can search for.  In this case, Individual is the only Type allowed.
  • Alan French:
    Thanks Alan, I honestly did not even know there was a difference between the two! I made the adjustment and the add went off without a hitch. Thank you!
  • Jen Claudy:
    Thank you for the tip Jen. I honestly did not realize that individual was an option, I guess I've only ever run constituent queries. Luckily it was wasy to change and my add went through perfectly, thank you!
  • I've been using RE for almost 15 years and sometimes I forget about this and have a mini freak out when I can't find my query.
