Changing Wrappers on existing Donation Forms to be responsive.
Hi,
Does anybody know the easiest way to do this? You can't just toggle the form from standard to responsive.
You should still set the form layout to responsive on your donation form setting.
The catch/quirk (which I believe still relevant at this time of writing) -- On the associated page wrapper of which the form is set to use, to trigger the default stylesheet for the form responsiveness, copy paste and don't forget to save the following value into your Additional attributes for the BODY Tag section within Step 3. Body Tag Attributes setting
class="[[?xxtruex::x[[S80:mobile]]x::mobile::]]"
regards,
DanielTim Wermund:
Hi,
