Organizing Contacts for Mailings
I'm trying to determine the best way to track contacts in our database. Currently, when we run receipts letters are generated for each contact that an organization has. It's inefficient, but helpful since we have multiple events throughout the year with contacts that change from year to year. Since our events repeat each year I was thinking about creating a contact attribute for each event. That way when it comes time to run receipts the correct contact could be pulled.
Has anyone else had trouble organizing their contacts? How did you manage it?
Have you considered defining by contact type for each event? If each event uses the same receipt it wouldn't work - you'd have to go with something else like attribute. But I would assume receipt/thank you is specific to event. If so, you can configure receipt function to pull contact by type in a hierarchy. We do this to pull correct one for capital campaign vs. annual.
To keep it accurate, some of it will just require busy work of updating info from year to year.
Just one idea.2 -
Lawrence Willim:
And yes, this will take constant upkeep, because contacts are always changing. That is a challenge for all of us :-)
You can also use Contact Attributes --
- We have our Contact Types defined simply as Primary, Secondary, Other and use these for broad/general mailing purposes
- For more specific purposes, we use contact attributes - including coding the Gift Acknowledgement Contact.
- The only downside for using attributes is that they are not really visible on the relationship screen.
