Constituent batch issues
Has anyone else been experiencing annoying issues with constituent batch entry? After entering a few constituents without problems, all of a sudden the primary addressee and salutation will disappear on the one I'm currently working on. Then I get the following error message: "Object variable or With block variable not set." Support said I needed to exit and sign out of RE and then get back in. I'm having to enter hundreds of constituents so this doesn't seem like a very efficient solution. Help!
Robin Richardson:
Has anyone else been experiencing annoying issues with constituent batch entry? After entering a few constituents without problems, all of a sudden the primary addressee and salutation will disappear on the one I'm currently working on. Then I get the following error message: "Object variable or With block variable not set." Support said I needed to exit and sign out of RE and then get back in. I'm having to enter hundreds of constituents so this doesn't seem like a very efficient solution. Help!This happened to me a long time ago, and I think changing the order of the columns helped. Also don't Ctrl+S before you get to the end of a row. I hope this helps!
