Exporting Zip-codes as a string and not an integer
I export my member information to a website on a regular basis and must do so as a CSV file. The website, so as to integrate with a geolocation system (so folks can see where they are by zip code) needs to have the zip code as a string, not as an integer. Is there a way I can change the zip code field so that it doesn't export as an integer? thanks
Margaret Argyelan:
I export my member information to a website on a regular basis and must do so as a CSV file. The website, so as to integrate with a geolocation system (so folks can see where they are by zip code) needs to have the zip code as a string, not as an integer. Is there a way I can change the zip code field so that it doesn't export as an integer? thanksHi Margaret,
You can't do it in RE as the datatype of the field is determined in SQL. You can though convert the data in excel by using TEXT function.
Tom
3
