Phone number is now a required field for contacting POTUS
Hi Rosie -
Yes, this is correct. The Whitehouse made phone number a required field. If you already had a live campaign targeting POTUS before the release you do need to go in and update this manually.
You can find the release notes on this here: https://www.blackbaud.com/files/support/helpfiles/luminate-releasenotes/Luminate_Release_Notes.htm#Luminate_Online/current.htm
Caroline0 -
Caroline Stuart-Freas:
Hi Rosie -
Carolinewe have an alert that needs to go out today, and we are unable to edit the boxes in step 5 to make the phone number required! i have an open support ticket on this issue. Has anything changed with the phone number requirement? Is anyone else having trouble editing the check boxes in step 5 (select contact fields)?0 -
Bev Stanton:
Hi Rosie -
Carolinewe have an alert that needs to go out today, and we are unable to edit the boxes in step 5 to make the phone number required! i have an open support ticket on this issue. Has anything changed with the phone number requirement? Is anyone else having trouble editing the check boxes in step 5 (select contact fields)?Malana in support came to the rescue!! We were unable to edit the contact fields because we had already selected the white house as a target. Here are her instructions in case anyone else has an issue with this in the future:
In researching further, it seems that we are not always able to mark fields as required when a target is already selected for the action alert. To get around this, we would want to remove the targets for the alert, save, and then add the phone as a required field, and save again. We can then return to the targets and add them appropriately.1 -
Thanks for sharing Bev - you did the right thing by going to support in this instance and I'm glad it was addressed in a timely fashion. Thank you for sharing on this chain so others can see.
Thanks for sharing Bev - you did the right thing by going to support in this instance and I'm glad it was addressed in a timely fashion. Thank you for sharing on this chain so others can see.Caroline: we are also seeing deliverability issues again--this has occurred in the past due to changes with the white house form. So i have submitted another ticket. Curious if others are having issues.0
